Injectors
Old Feb 8, 2009 | 01:31 PM
mook99ta's Avatar
Default Injectors
I have a set of injectors off of a 02 ZO6 corvette pn#12561462 are they any different from my 99 LS1 injectors pn#12456154?
Second question are they interchangable if the ZO6's are bigger, without a tune?
Old Feb 8, 2009 | 03:23 PM
405HP_Z06's Avatar
12561462 are 28.8 lb/hr @ 4 bar, 12456154 are 26.6 lb/hr @ 4 bar. You will need to modify the PCM regardless of which way you go.
Old Feb 8, 2009 | 03:41 PM
nemss1's Avatar
yes, a tune will be needed when swapping to injectors with dif specs
Old Feb 8, 2009 | 04:14 PM
mook99ta's Avatar
Is there any real benefit with the ZO6 injectors for a bolt on LS1 over my stock LS1 injectors?
Old Feb 8, 2009 | 04:18 PM
nemss1's Avatar
on a bolt-on car, no. most people swap to higher power injectors if they need to like H/C setup
