O2 Question???
You mean the O2's aren't switching?
They are bad. I got 1,200 miles out of a set of bosch sensors.
The only reason I went with bosch is because I had two random O2's from a junkyard wire nutted to the ends of the originals. Those worked fine according to hptuners scans.
Now I have denso O2's.
Why in the hell would you replace all four O2's if you gutted the cats though?
The black could be a fouled or cracked spark plug, bad injector, etc. Just because the O2's keep going bad doesn't mean they are the problem, sometimes something upstream causes it.
And once an untuned front sensor slows down or flatlines, it's stuck in open loop.
