A.I.R. Removal Question
Old Oct 12, 2003 | 07:57 PM
PacerX's Avatar
Default A.I.R. Removal Question
There is a small vacuum line that runs from the electrical doo-dad (the other line runs to the rear of the intake manifold) on the driver's side head to the actuator that splits the line from the A.I.R. pump to the exhaust manifolds.
What do I do with this line? Cap it off?
Old Oct 12, 2003 | 08:22 PM
BigBake's Avatar
Default Re: A.I.R. Removal Question
Yep, cap it off.
Old Oct 12, 2003 | 08:45 PM
ss rally red's Avatar
If I remember correctly once you delete the AIR pump you don't need to do anything with it.
Old Oct 12, 2003 | 08:50 PM
PacerX's Avatar
Cool!
Now....
About the doo-dad on the driver's side valve cover...
Looks like that thing just ran out of stuff to do, so can I remove it and cap off the vacuum line coming from the back of the intake?
Old Oct 12, 2003 | 08:52 PM
WILWAXU's Avatar
...so can I remove it and cap off the vacuum line coming from the back of the intake?
That's what I did.
Old Oct 12, 2003 | 09:05 PM
PacerX's Avatar
John,
What does the other little vacuum line going to the intake do?
The big one obviously goes to the brake booster.
Thanks!
Old Oct 13, 2003 | 03:06 AM
Jabroni's Avatar
One of them operates the A/C controls. Careful not to pinch it when swapping intakes.
Old Oct 13, 2003 | 07:11 AM
PacerX's Avatar
Gotcha.
Thanks a ton!
