alternator swap writeup? the search is down
Old Feb 21, 2009 | 01:02 AM
aaron653's Avatar
Default alternator swap writeup? the search is down
thanks.
Old Feb 21, 2009 | 01:14 AM
94'BLKBRD's Avatar
Disconnect your battery.
Remove the belt.
Remove three 15mm bolts(not sure if the rear bolt is 15mm). Two bolts are in the front and one in the rear.
Unplug the alternator wiring harness(small red wire).
Play with the alternator until it comes out.
