Passing Emissions Test In Ohio
Old Feb 22, 2009 | 05:46 PM
Nick_Rapitis's Avatar
Default Passing Emissions Test In Ohio
I need to pass an emissions test where they do a brief visual inspection and the obdII test....if i get pacesetter lts and a catted y what do i need to do to pass the test?
Old Feb 22, 2009 | 09:33 PM
KirkEvil's Avatar
You need to handle the rear o2's: tune them out, get oxygen simulators, or have rear bungs welded after the cats.
You will also have to get headers with AIR/EGR hook ups, or have them tuned out if you delete them.
Old Feb 22, 2009 | 10:50 PM
Samba242's Avatar
I passed in Cuyahoga County with QTP longtubes, a custom catted-y pipe and a good tune. A check engine light or stored code will fail you. Apparently the program they use to check the OBDII doesn't notice deleted stuff, since my rear O2 sensors were deleted. They checked under the car briefly with a mirror and apparently the 100% not stock exhaust didn't raise any red flags. They even commented on how good the car sounded!
Old Feb 23, 2009 | 08:39 AM
dre2013's Avatar
over the past few yrs i have found the easiest way is to register your car to a non-emissions county...i live in summit, but go to school in stark county(which doesnt req emission testing)....you can use a friends address, or you can do what my buddy did(not recommended..): he just went thru the phonebook, and used a random address in stark county. lol. its worked for about 2 yrs though
Old Feb 23, 2009 | 09:38 AM
well i am going to have all the o2s in and all the air stuff...does that mean i will be ok? i head it will still probably throw a code....
Old Feb 23, 2009 | 12:13 PM
Pushead's Avatar
I passed with no EGR or AIR, Catted Y and a tune. I have the O2 sensors in mine with no problems, so I only had the EGR and AIR tuned out. There wasn't a problem.
As mentioned, they'll use a mirror to check for cats, hook up to the ODBII to check for codes, and run you on the dyno.
What exactly are you planning on doing to the car? I know the LTs and Catted Y, what else?
Old Feb 23, 2009 | 12:20 PM
well it already has a lid with the fast toys intake...373 gears, 160* powerstat, lm1 with cme, kyb agx gas shocks, and i've been using the hpp3 programmer for now...
Old Feb 23, 2009 | 02:20 PM
Pushead's Avatar
Stock cam and heads? I can't believe you'll have a problem with it throwing codes. Especially after the computer has had some time to reprogram itself. Do you have a ODBII reader that can delete freeze frames?
 Michael S. Palmer
Old Feb 23, 2009 | 02:33 PM
qwk93ta's Avatar
The state stopped all that testing is Southern Ohio a few years ago. You can reqest a collectors plate, I had to send the state pictures of my 93 T/A and receipts totaling $5,000 so I did not have to get my car tested any more.
Old Feb 23, 2009 | 03:20 PM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
Scioto County doesn't do testing
Old Feb 23, 2009 | 03:43 PM
Viper's Avatar
I did the collectors plate in Ohio. Have to prove you drive another car as your primary. Plates stay the same and a new sticker costs me $60 a year. If you look at my signature there's no way I'd pass emissions.
http://bmv.ohio.gov/vehicle_registra...tor_plates.htm
Old Feb 23, 2009 | 06:28 PM
yes stock cam and heads, all stock internals, just what i mentioned....i heard if you get a code tuned out it may show up as "not ready" when they plug in the obdII system...is that true? or since i have cats and my o2 sensors will i be ok...some one told me by placing the o2 in a different position it will throw off the computer...
Old Feb 24, 2009 | 02:14 AM
Z28/2002's Avatar
Originally Posted by Viper
I If you look at my signature there's no way I'd pass emissions.
Same here, I'm running a carb on my TA
Old Feb 24, 2009 | 10:26 AM
twitchtwice's Avatar
untrue, if you get the codes deleted professionally they will not show up at all.
Old Feb 24, 2009 | 10:52 AM
ok...what about with hp tuners? also will i even need to have that done since i am going to have my cats and o2's? ive heard that by relocating the o2s it could throw a code...
Old Feb 24, 2009 | 11:44 AM
Samba242's Avatar
Yeah, until he gets the random insurance verification mailed to the wrong address and ends up suspended and won't know it.
Old Feb 24, 2009 | 11:48 AM
anyone?
Old Feb 24, 2009 | 04:50 PM
anyone?
no from what i understand hp tuners will not completely get rid of the codes.
Old Feb 25, 2009 | 08:56 PM
any more info on this? i would appreciate it!
Old Feb 25, 2009 | 09:36 PM
vsocks1's Avatar
If you disconnect the battery or flash the pcm you will get your emmision codes set to "not ready". Takes a certain amount of drive cycles afterwards to show ready. You can have O2's set to not report codes and still pass!
