SLP vs Texas Speed True Duals
i was going to say stick with a catback if its your DD because TDs are loud.... but when your comparing them to a loudmouth1 i say its your choice!
honestly with a catback only, there will be NO difference between the exhausts (minus flowmaster). at least not enough to affect times. get what sounds good to you, that will make you the happiest.
heres a link.
http://www.youtube.com/watch?v=mTzLfS1nRuU
What kind of y-pipe do you have? If you have Pacesetters with the crappy Pacesetter or TSP y-pipe, where the merge is horrible, I'm going to put my money on the TD's. What is your entire system comprised of? What y-pipe are we weighing in vs. the TSP TD's?
It's very hard to make TD's that outperform a y-pipe on these cars because the TD's don't fit properly and they're not even close to equal length on each side. That and the merges typically suck on the custom systems I've seen. TD's make more power in a perfect world, but if you're comparing crush-bent TD's with a crappy merge and horribly uneven lengths running off each header collector, you're going to lose power with TD's. Unfortunately, most custom TD's I've seen are poorly made and I'm sure a y-pipe would outperform them
