TB question
Old Feb 28, 2009 | 09:55 PM
redlineracing's Avatar
Default TB question
Hey guys.
Had my throttle body ported by a forum sponser here. I installed it today.
The problem it, the car now idles a little higher than usual. I dont think the butterfly is closing all the way. It also takes a little longer to get to idling RPM's after you press the gas. Is this anything to be concerned about?
Thanks alot.
-Lucas
Old Mar 1, 2009 | 12:07 AM
01ssreda4's Avatar
does it have the bumpstop mod done? my ported idled funny for a couple trips when i first put it on there. i did the bumpstop mod later and it started idling funny again...kinda like what you describe.
Old Mar 1, 2009 | 01:11 AM
quikrnmost's Avatar
The TB has too much air getting past the blade. You can try adjusting the idle screw on the side, but I bet it won't help. The TB has been ported too much around the blade. A good way to test this is to put a piece of tape over the hole on the blade. I bet you a 6 pack it will fix it. You need to weld or epoxy that hole up or get a C5 blade that doesn't have a hole in it.
Old Mar 1, 2009 | 01:17 AM
thunderstruck507's Avatar
if you hold the tb up to light can you see around the blade?
Old Mar 1, 2009 | 02:21 AM
nemss1's Avatar
may be over-ported and air is getting around the edges of the blade. also knife-edging the blade, i wouldnt recommend because of this
Old Mar 1, 2009 | 11:36 AM
Well is this a problem? Is there any performance lost or is it just the funny idle?
Old Mar 1, 2009 | 01:14 PM
Anybody? Come on guys, I need some help.
I don't mind the higher idling RPM's if there is nothing for me to worry about..
Old Mar 1, 2009 | 03:14 PM
quikrnmost's Avatar
Come one? You got the advice you needed to fix it. Did you try putting tape over the hole? Try it and report back.
Old Mar 1, 2009 | 07:48 PM
Sgt Drags's Avatar
When I installed my ported T/B from revxtreme, it idled higher than normal. Reason being was that they gave me a t/b off of a 98 Camaro. The difference was in the cam on the side of the throttle body was a little bit smaller than on a 2001 camaro throttle body.
If you have both throttle bodies, you might want to check and make sure the cams are the same size on both throttle bodies.
Old Mar 1, 2009 | 08:13 PM
quikrnmost's Avatar
That shouldn't affect the idle. The 00+ throttle cables are longer and with the shorter length of the 98-99's, the cable would have been longer than needed. So there should have been slack in the cable.
Now if you have a 98 and tried to install a 00+ throttle body, the cable would be too short and wouldn't allow the blade to close completely, creating a serious problem.
Old Mar 1, 2009 | 08:16 PM
Ok guys. thanks for all the responses.
I was thinking about it today and I had a feeling it was the IAC. I went out and checked it, and the o-ring didnt seat properly. I reseated it and no more problem!
