erratic idle and surging at low speed
i installed a ls6 intake manifold two days ago. Well everything went according to plan...broke my oil pressure sending unit and swore more then a sailor. Well When i started my car up (98 trans am, no internals mods) I noticed erratic idle..the car would idle real low..the 500rpm range. The car never has stalled but gets close. When i let it warm up it will flucuate between 500 all the way up to 2k..however when its in park it ranges from 1k-2k..in gear drops to 500.
I unplugged my maf and the idle stopped searching so much and sounded good at a little under 1k...but then in neutral it was up to 1500..I read here that the IAC could be dirty. It was filthy but after i cleaned it and did a pcm relearn it still searches a lot..with terrible lag in low end throttle response and low end driveability and bad idle quality
...any suggestions will be greatly appreciated Trending Topics
