Traction Control Delete....How to??
Old Mar 6, 2009 | 11:09 PM
nemss1's Avatar
u can get them at the GM 'stealership'
Old Mar 6, 2009 | 11:55 PM
Magnet's Avatar
I have an 01, would a 98-99 cable without traction control work? or does it need to be 01-02 without traction control? I assume they are different b/c the TB's are slightly different but I'm not sure since its for no TCS..
Old Mar 7, 2009 | 12:05 AM
nemss1's Avatar
yes u will need a TB cable frm 00+
Old Mar 7, 2009 | 12:32 AM
Magnet's Avatar
Do you need more than one cable? one for cruise one for throttle or are they the same cable?
here's the part numbers for the cables...
LS1 throttle cable (98-99, without TCS) = 12565559
LS1 throttle cable (00-02, without TCS) = 12565560
looks like about $30 shipped for gm parts direct..
Old Mar 7, 2009 | 07:11 PM
nemss1's Avatar
yes, u will need more than one cable, cruise and TB. thats if u wanna keep cruise
Old Mar 7, 2009 | 07:44 PM
HMERacing's Avatar
Originally Posted by noriceinside
its way simpler than everyone thinks. just unplug and remove the TCS module. once that circuit is open the TCS is disabled just as if you hit the switch. leave the rear end the same. all you need to do is get a new throttle cable and a new cruise control cable.
relocating it is a little janky, but at least its all still in tact and functional. and even though you dont wanna hear it, just look how good it looks simply by relocating it.
That looks great, I may try this myself.
Old Mar 7, 2009 | 09:22 PM
wht01ws6ta's Avatar
^^That does look good. WTF did you relocate it to? I don't even see it.
Old Mar 8, 2009 | 04:54 PM
Johns00Z28's Avatar
Is there a way to turn the light off on your dash once your delete it?
Old Mar 8, 2009 | 11:03 PM
BlackBirds's Avatar
its up by the PCM, see the cabling running under the cowling from the TCS module to the driver's side of the car? yeah i know relocating it looks just fine but i might as well just get rid of it haha. thanks for your help guys, sounds like i just need to pull a fuse and replace cables...easy enough
Old Mar 8, 2009 | 11:16 PM
sroach20's Avatar
do like me and rip the led out, or you could tape over it.
Old Mar 8, 2009 | 11:26 PM
noriceinside's Avatar
its behind the PCM. you have the remove the bracket the TCS mounts to and it will fit there fine, i didnt even worry about securing it. no problems and it still works great.
Old Mar 8, 2009 | 11:58 PM
  #32
BlackBirds's Avatar
yeah...gonna just pull it out myself.
Old Mar 9, 2009 | 03:25 AM
  #33
nemss1's Avatar
also, there are certain wires u could splice together to get rid of the 'dummy' lights. dont remember which wires though
Old Mar 9, 2009 | 10:27 PM
  #34
wht01ws6ta's Avatar
Where are these wires located? Easily accessible? Do you know what do you have to do to get to them?
Old Mar 9, 2009 | 11:09 PM
  #35
nemss1's Avatar
the wires are off of the harness to the ABS block....i think. i dont quite remember, but there is a thread on here somewhere that tells exactly what wires to splice together and u may be able to find a pinout for the ABS harness
Old Mar 10, 2009 | 10:05 AM
  #36
SantaCruz163's Avatar
Instead of grounding TCS wires you can simply buy a non-TCS ABS module if you can find one at a reasonable price. I want to remove my TCS as well and started looking into what is involved in delete.
I was thinking about also deleting my ABS which will make buying a Moser 9in. cheaper than if I needed a 3 or 4 channel rear end.
The only requirement I must have is the ability to still have cruise control.
Old Mar 10, 2009 | 10:41 PM
  #37
nemss1's Avatar
thats true. also have to buy the ABS module under the dash frm a non-TCS car
delete is simple, u can do away with:
*ABS module
*ABS computer under dash
*wheelspeed sensors
u can still have cruise control. cruise runs off of its own computer. just need a diff cruise cable going directly to the TB
Old Mar 11, 2009 | 01:59 PM
  #38
00Camary's Avatar
I woule really like to do away with TCS and Cruise. Too bad there is not a write up for this. Not to mention it is a little bit of a weight savings.
Old Mar 11, 2009 | 03:17 PM
  #39
BlackBirds's Avatar
yeah cruise is a must...gotta have it for those long drives. ABS for me is also a must, just in case I have to slam on the breaks I'd like to be able to stop
Old Mar 19, 2009 | 02:35 PM
  #40
BlackBirds's Avatar
well, nevermind I found a car WITHOUT TCS and happily drove her home last weekend. so I hope this thread at least helps other people who have TCS and want it gone. Thanks everyone that helped!
