Those who have installed TSP Duals come in!
Alright so for those of you who have installed the TSP Dual kit, how did you go about drilling the holes for the hangars? Did you just cut the carpet or pull it all up? Im thinking about just drilling from the bottom to see where on the carpet it pokes through and slitting the carpet there...Also how many bolts hold the rear seat in and roughly where are they located? Any other tips would be greatly apprectiated!
Thanks,
Josh
Thanks,
Josh
How you are thinking about doing it is the way I did it. Just be careful when the bit goes through it will want to suck up the pad. I also made some rubber isolators for between the body and the hanger, don't know if it actually helped but its there. And the buckets have one 13mm bolt in the middle of the front of the seat. If I remember right you don't need to remove the upper part of the rear seats.
