E-brake switch location
Old Mar 12, 2009 | 02:26 PM
shtnfrds's Avatar
Default E-brake switch location
the brake light is on in my dash. i just recently did some swapping in the rear end. not new gears, just the whole thing all together.
I need to know where the e-brake switch is to test it to see if its bad or if the problem might be somewhere else.
Thanks.
Old Mar 12, 2009 | 02:55 PM
2001NBMZ28's Avatar
Have you already tried cycling the ebrake handle a few times? Same thing happened to me when I swapped mine. Make sure the brakes were bled correctly and the fluid level is OK too. Believe the ebrake switch is in the colsole.
Old Mar 12, 2009 | 11:00 PM
nemss1's Avatar
under the upper console. easy to removed. just remove the 2 hex screws for the upper console under the console lid, remove the staple that holds on the shift **** to remove the shift **** and pull up on the upper console
(easier if u put on the ebrake and move the shifter to remove the upper console)
should see the ebrake sensor on the ebrake assembly
Old Mar 13, 2009 | 01:06 AM
shtnfrds's Avatar
would that really have anything to do with the brake light? i would think if there was a bleeding problem or a low fluid issue that would cause an abs light?
