243 question
See sig below!
boost compression and build a little bit more power.
if you do put thinner gaskets, it would be worth checking the pr length.
if i'm not mistaken, the pushrods from the vette will be the wrong size for your ls1...since the ls6 cam has a different base circle.
don't quote me on that though.
stock 243s plus the ls6 intake...should easily see 25hp.
you'll proably need it retuned....more air will likely make it lean
imo find a 02 ls6 cam, with matching pr, ugrade the springs, mill .005 just get flat surface and use 6.0 mls gaskets. even with these parts u will be at
425bhp range with stock manifolds. pretty much same spec as a ls6 but with conventional valves.
