E-cut questions
which E-cut has been the most reliable?
and where and how do you run the wires? do you have to drill a hole in the floor?
i would also like to see some pics please if anyone has them...any and all info will help thanks alot guys
as for brands the 2 best brands are QTP and DMH.
dmh having a 4yr warranty and qtp i believe has a 1yr warranty.
you dont have to drill any holes theres a plug that its under on the rear passenger seat ujust have to splice it up alittle and run the wires through there.
And where it asks if you want the QTP SS CutOut, select YES
can somebody post some pics of exactly where under the back seat to put the cut out? also do you have to remove the back seat and the carpet to run the wiring? thanks for the help guys!
here is a pic of a cutout under the rear passanger seat. You can see the black rubber grommet where you will need to run the wiring inside the car
