Best way to clean O2 sensors
I just took my 02's out to look at them and they have a little carbon on them, what is the best thing to clean them with? Im just worried if i use brake cleaner it might mess with the sensor reading the wrong stuff when I put them back in
Cleaning the carbon off won't do anything at all, I used to do it cuz it seems right but in reality it doesn't, the outside is just a casing with holes or slits in it, the exhaust goes through the passages and the amount of oxygen is read.....as long as the holes, slits or whatever it has is open and not clogged then that's all you can really do.
How can you check to see if the glass is cracked?
The reason I ask is because I had some water sucked through the engine and now it idles at 1500-2000. My rears are deleted and the code is removed. I'd really like to check them some way because I don't have any money to waste.
Thanks.
Thanks.
OUCH! $175
There is a reason I'm driving a 1989 Vehicle!
Lol
