FAST intake worth it i my situation??!!
We can talk numbers and dyno grpahs all you want but the REAL determining factor is when you hit the gas pedal for the first time. The smile it will put on your face will make it worth every penny, and I dont have headers or anything. Stone stock!!!!
- he has a 6.0 block, not 5.7
- he's comparing an LS2 intake to the fast intake
- not sure what heads he has, not 241's anyway
I have a BIG FAT picture of an LS2 appearing engine with every post, there is nothing Im not sharing. I have an LQ9 shortblock with Stock LS2 cam, Stock LS2 heads, Stock LS2 intake, Stock LS2 Throttle body, with Stock LS1 exhaust manifolds. Its an iron reproduction of a stock LS2.
It was pulled out on the dyno way past its peak just to see since I had 918 springs and .105" wall pushrods. It actually probably needs to look like this, since the engine was obviously was running out of breath....
I do have a Gen III engine. 2002 LQ9 is a Gen III.
https://ls1tech.com/forums/generatio...2-vs-fast.html
And I think the first post I disagreed with you a long time ago was in a thread about a bone stock 98 LS1. You told that guy he should get a fast intake too. Bad advice.
But sweets10v8 results speak for themselves; 21rwhp more with nothing else than the bare FAST is a kickass result.
__________________
2001 ws6, m6. MODS: Passeters long tubes, ory, ASP Pulley,Spintech muffler, slp lid, Comp XER 224/228 581/588 cam 113 LSA 394rwhp 384tq.
12.8 @110 on street tires for now before cam
I see youre just sharing real results and I appreciate.
I checked the dyno section since my first post here about the FAST setup in almost every situation and I know the results vary a lot from every setup. The only real fact is the more mods you have and the better the FAST is. Some plp with stock heads and cam had very good results, like you, but some just saw from 5-10hp..
I placed my order on a ported FAST 92mm today, I can tell that I can only hope that I will be one of the plp that will get the FAST magic results. 21rwhp is more than I really hope.
I'll be back with the results in 2-3weeks.
some of that is due to difference in dynos. not everyone does a before and after, same day, same dyno, same tune....
that's why i did mine that way. it was as close to apples-2-apples as possible.
