Vuibration normal?
Old Apr 11, 2009 | 04:08 PM
Zerokube's Avatar
Default Vuibration normal?
I started my car up and let it get to a normal driving temp and i kinda revved it to about 2k rpms and im noticing alot of vibration throughout the car, normal?
Just noticed i misspelled the thread title lol
Old Apr 11, 2009 | 04:21 PM
DaveX's Avatar
Well if it never did it before then all of the sudden started vibrating, it sounds like something is wrong.
Old Apr 11, 2009 | 04:57 PM
dutinsss's Avatar
X2 if it does something it normally doesn't do, that means it's not normal
put it in park and rev it a little and try to track down where it's coming from.
Old Apr 11, 2009 | 05:00 PM
Zerokube's Avatar
it's manual. I also cleaned the throttle body to see if it would help my loss of power/acceleration. Gonna replace the TPS. My brother thinks it's a logged cat
Old Apr 12, 2009 | 12:36 PM
ds98formula's Avatar
Try putting it in gear hold the clucth in and rev it up with the brake depressed and see if it trys to move could be the clucth. Could also be flywheel as that smooths out the power from the engine.
Old Apr 12, 2009 | 07:34 PM
Zerokube's Avatar
Tried keeping the clutch in and revved slowly and it stills vibrates most of the car. I do feel like my clutch is slipping, my gears occasionally grind.
Old Apr 12, 2009 | 09:29 PM
RevGTO's Avatar
Pontiacerator
A friend's car will vibrate significantly when revved in neutral at about 1200-1400rpm. We put it on a scanner and tested for everything. There were no codes, no miss or anything. The car runs normally otherwise.
Conclusion was that it's something internal affecting balance ... perhaps the flywheel, although it's relatively new. We decided it's not something worth taking things apart to find.
