who sells catch cans?
Old Apr 15, 2009 | 10:58 AM
silverLSWON's Avatar
Default who sells catch cans?
i am looking to buy an oil catch can but i don't really know which ones actally work and who would sell them. the only one i can find is revextremes and i heard that one works pretty well. i also heard of amw i think??? just looking into my options for a catch can. also what sponsors sell them?
Old Apr 15, 2009 | 04:56 PM
rel3rd's Avatar
I got mine off of this board from Mike Norris Motorsports. It works well.
RevExtreme one is supposed to be nice as well.
Old Apr 15, 2009 | 07:11 PM
thanks!!! does it wobble alot when your car is idling?
Old Apr 15, 2009 | 07:17 PM
vsocks1's Avatar
^^^^ I agree!!
Old Apr 15, 2009 | 07:53 PM
rel3rd's Avatar
wobble? No. It's secured in the bracket by a set screw, and the bracket is bolted onto the cylinder head. No wobbles.
Old Apr 15, 2009 | 08:35 PM
ok good, a friend of mine had the revextreme and it wobbles like crazy!
Old Apr 15, 2009 | 08:58 PM
EndlessSummer85's Avatar
I have the Rev-extreme catch can and it's on there solid, no "wobbles" at all.
Old Apr 15, 2009 | 09:13 PM
JFM-jr's Avatar
I like the REV Extreme setup I have.
Old Apr 16, 2009 | 06:17 AM
toadzq8's Avatar
+3 for the Norris Motorsports can
Old Apr 16, 2009 | 01:15 PM
WS6nJAX's Avatar
Restricted User
bump for the Norris catch can.
Old Apr 16, 2009 | 04:01 PM
thanks for all the info guys. i'm prob going to order one before the weekend
Old Apr 16, 2009 | 09:44 PM
chrs1313's Avatar
mine still seems to get oil in the intake and give me a little knock...so i swapped out the brillo pads for some S.S. wiremesh, and a fiberglass custom filter i made at work...same material used to filter oil mist from huge vacuum pumps to 3 microns at 99.97% efficiency...haha there should be no oil in my intake now
Old Apr 17, 2009 | 02:21 PM
rel3rd's Avatar
I actually had to add a small inline filter in the other breather hose, since that one hooks to the throttle body and was drawing in some oil too.
Old Apr 17, 2009 | 08:13 PM
bigdsz's Avatar
A coalescing filter is the only real way to stop oil from getting into the inlet manifold.
Old Apr 18, 2009 | 11:29 PM
chrs1313's Avatar
once i see that term i know we are on the same page...
Old Apr 19, 2009 | 02:55 PM
405HP_Z06's Avatar
Did you swap the line configuration with the modified filter material inside the can?
Old Apr 20, 2009 | 11:05 AM
rich Z's Avatar
Wouldn't this cause pressure buildup once the filter soaks up oil thus causing oil leaks.
Old Apr 20, 2009 | 02:07 PM
chrs1313's Avatar
I think what you are looking for is back pressure…and yes it will cause slightly more back pressure but this is true for any filter that is of higher efficiency…as long as the filter doesn’t cause as much pressure drop as what the intake manifold can pull there will be flow…and I don’t seeing this filter cause as much vacuum that will be inside of the intake…what is vacuum level in our manifolds…
Old Apr 20, 2009 | 02:14 PM
chrs1313's Avatar
I am not sure if I understand your question, but yes everything is setup the same way and the filter is inside out flow…causing the oil to be filtered and pushed though the media…coalescing on the outside of the filter and dripping to the bottom…
Outside in flow would not work cause the oil would coalesce on the inside of the filter and have nowhere to drain…with this kind of setup outside in flow there needs to be a suction line on the I.D. of the element or a drain back flap will work too…
Old Apr 20, 2009 | 02:33 PM
bigdsz's Avatar
A 20 micron borosilicate coalescing filter removes virtually all the oil mist in low volume-low pressure applications without saturation issues.
