Band clamp issue...
Old Apr 18, 2009 | 10:06 PM
98RedBird's Avatar
Default Band clamp issue...
I got around to installing my LPP Y-pipe tonight and the fitment is great. However, the band clamps that they supplied are fitting in a very awkward way. Because of the HVMC the front of the band clamp has a gap between the collector and the clamp. The rear of the clamp that is on the Y-pipe is fine.
Suggestions on what to do??
Old Apr 18, 2009 | 10:11 PM
z28hustle's Avatar
this one time in band clamp
Old Apr 18, 2009 | 10:13 PM
bene's Avatar
Trunion King
That's retarded. Why would they supply you that stuff w/ a gap like that. I'd replace it w/ V band style clamp.
Old Apr 18, 2009 | 11:54 PM
98RedBird's Avatar
Well, I think it's because of the HVMC. It necks down and the band clamp cannot make up for it.
Old Apr 19, 2009 | 12:00 AM
bene's Avatar
Trunion King
True, however you would think they know this already and fix that problem. If it holds pressure I guess they wouldn't see it as a problem.
Old Apr 19, 2009 | 12:54 AM
98RedBird's Avatar
Yeah. I am hoping there are no leaks...
We'll see I guess. I'm not sure what other options that I have though.
Old Apr 19, 2009 | 01:25 AM
Undertow74's Avatar
Weld it!! i hate those silly band clamps. sometimes they are better than u bolts, sometimes not. i just welded my exhaust, no leaks!!
Old Apr 19, 2009 | 12:12 PM
TheSilverOne's Avatar
were those clamps preformed or flat originally?
Old Apr 19, 2009 | 12:17 PM
1BADBLACKBIRD's Avatar
alot of times you need to overtighten the clamp one side more than the other...at least on the flat clamps....they assume the perfect shape....don't be afraid to keep tightening that bitch down some more. I run a muffler shop and have had this exact problem before, and had much greater succes with the flat, non-preformed clamps!
Old Apr 19, 2009 | 12:37 PM
MeentSS02's Avatar
Kleeborp the Moderator™
I've tried that kind of clamp many times, but never seemed to get them to work. This time around I went with Dura-Seal clamps (Google it), and slotted the pipe. Definitely sealed MUCH better than those pre-formed, thin stainless bands.
Old Apr 19, 2009 | 01:02 PM
98RedBird's Avatar
It was a preformed band. So that step that you're seeing was already there... And it's pretty damn tight. I'm afraid of bending the collector if I go any tighter.
