torque limiter
Old Apr 19, 2009 | 07:03 PM
THEBRAD's Avatar
Default torque limiter
anyone ever run a torque limiter or strap on thier fbody? im talking about some sort of bar that connects to say the frame and the engine to stop it from moving so much. show me some pics
Old Apr 19, 2009 | 09:09 PM
ShortChevy's Avatar
I don't know of any but solid motor mounts should do the trick. Vibes arn't as bad as you think even in a daily driver.
Old Apr 20, 2009 | 12:25 AM
THEBRAD's Avatar
yeah i didnt really want to have to solid mount it, this i can take off and on whenever
Old Apr 20, 2009 | 05:39 AM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
Your car doesn't make enough power to need one and the motor mounts are probably wore out
Old Apr 20, 2009 | 06:41 AM
The Alchemist's Avatar
UNDER PRESSURE MOD
Do poly motor mounts and a poly trans mount as well, but you need to grind the bottom of the trans mount to get it to sit flush.
The motor mounts keep the motor from rocking left to right, and the trans mount keeps it from rocking up and down if that makes sense.
Old Apr 20, 2009 | 09:21 AM
jimmyblue's Avatar
Moderator
I've seen one pic of somebody using a load binder
strap. I wouldn't recommend that.
I had an old Buick Wildcat motor once that had a
factory torque strap, a steel "bridge" between two
head bolts (outers were not under the vale cover)
and a swaged cable from that to the upper A-arm.
Looked solid, it was a 445 lb-ft motor back in the
day on soft rubber mounts.
Old Apr 20, 2009 | 01:43 PM
THEBRAD's Avatar
yeah dont need to know how to install mounts or what nots just need a pic
Old Apr 20, 2009 | 01:44 PM
THEBRAD's Avatar
and this isnt my setup anymore.
 Michael S. Palmer
