Alternate Smooth bellows...see inside
Old Apr 26, 2009 | 05:53 PM
Soul TKR's Avatar
Originally Posted by greatskiiiier
how much of a performance gain is to be had from this? i always heard the slp bellows was **** so i never investigated it
this looks good, but i think just some 4" ID rubber hose will have the same look IMO
minimal gain if any, but it's a cleaner look. The typical 4" ID rubber hose doesn't really fit correctly as it needs a slight bend to line up... which is the whole point of this thread...
Old Apr 26, 2009 | 06:22 PM
chrs1313's Avatar
^yup
Old Apr 26, 2009 | 07:22 PM
DaddySS's Avatar
Nice find
Old Apr 26, 2009 | 08:50 PM
greatskiiiier's Avatar
a weak rubber polymer will bend quite easily but it wouldnt look as nice, just trying to balance out my money between car and bike...
either way this looks like a kick *** alternative to SLP, good work!
Old Jul 10, 2009 | 10:32 PM
Sweetred95ta's Avatar
What can I do if I have a 90mm FAST TB, no MAF, and an SLP Lid? I measured it, and the connection piece needs to be ~7". The TB is 4-3/16" OD and the lid is 3-13/16" OD.
Old Jul 11, 2009 | 08:15 PM
NastyNate65's Avatar
So even if my intake is not recessed back 1 inch that 4 inch hose will be long enough? Sounds like a great idea btw
Old Jul 11, 2009 | 10:48 PM
TORCHD 02 TA's Avatar
Yup you can still use it. I jsut put mine on 2 weeks ago. And my lid is not recessed at all. I actually had to cut about 1/8" - 1/4" off....
Old Feb 9, 2010 | 10:04 PM
01 ss vert's Avatar
What about for the stock maf and intake guys?
Old Feb 14, 2010 | 10:38 PM
smok'nZ's Avatar
MASS seller approved
just ordered one i hope it fits better than my straight 4"
Old Feb 15, 2010 | 03:08 AM
MaxBlown's Avatar
Ive seen some pretty sic metal one out there
Old Feb 16, 2010 | 01:22 AM
uphigh07's Avatar
works for me. better then spending all that money on the slp one that does the same thing
Old Feb 16, 2010 | 06:51 PM
  #32
chrs1313's Avatar
it will fit alot better, the angle is pretty close to right on once trimmed a little...
Old Mar 6, 2010 | 11:31 PM
  #33
383camaroz28's Avatar
what size cuppling do i need for 85/85 setup, 3inch?
Old Mar 7, 2010 | 01:39 AM
  #34
Engine_HP's Avatar
not bad @ all,
nothing better than saving money and getting the job done right.
Old Mar 7, 2010 | 08:44 PM
  #35
chrs1313's Avatar
I would say the 4" I have a 92/85 setup and it works great...can't see the 7mm difference being that big of a deal... it is a hair over 1/4" difference
Old Mar 20, 2010 | 05:24 PM
  #36
studderin's Avatar
fits with the maff, this is what Im running. check out my intake test thread for more pics, and my build thread has a bunch too. Also I posted in there how it fits mint on the 92mm TB but little bigger on a 85mm maff. How you put the clamp on it, top/bottem/side. Changes how it tightens up the little 1/16 clamping, and you can use it to make it a 20* or 25* and get it fitting just right if you work on it. Its a great setup, tested a few differnt cams, and other parts had the lid off a lot of times, just taking the clamp of the TB and pulling eberything, gose right back on fast and fits up very good, 10secs-done.
Some other cars I work on with diffrent "smooth bellow" setups are a bitch, getting the lip clips in, and forceing everything for 15mins. F that.
Old Mar 22, 2010 | 12:49 PM
  #37
01'SSLSX's Avatar
Originally Posted by chrs1313
cost was like 25 plus 8 for shipping...not extremely cheap but works perfect for what i needed...was at my house the next day too...
updated link
man that turned out great, the fit looks perfect. i like the 22* bend
even my slp bellow doesnt fit that good(against the maf)
Old Mar 22, 2010 | 04:05 PM
  #38
Nitroused383's Avatar
MAF delete with 2 new clamps, slp lid to 85mm throttle body $31. Fits perfect and I gained 2 KPA above 4000 rpm. 6" long x 4" I.D.
Attached Thumbnails Alternate Smooth bellows...see inside-104_0237.jpg   Alternate Smooth bellows...see inside-104_0238.jpg
Old May 24, 2010 | 03:08 PM
  #39
Magnet's Avatar
Where did get this one, the same site?
Old May 24, 2010 | 05:21 PM
  #40
smok'nZ's Avatar
if anyone want the one chris showed the link to pm me i have ne i cant use now
