G5X2 with Victor Jr.
Would it be better to go with a higher lift lower LSA cam to match the Vic? Would an MS4 work well?
BTW, I use the search feature religiously. 61 posts, 3 years here.
Sorry if this is in the wrong section, didn't know whether it'd be better to put it in internal or external.
Thanks, Russ
what usually kills a vic jr is the elbow that people put on... and be sure to port-match it, the ports are not really well aligned but i think you are within 5-10 hp of what that cam will do with another intake (below in the lower rpms, propably above in the high)... if you are goung to tear into it and change cam.. get a custom one to suit your engine, stall, intake weight, use etc....
but why not run it now and enjoy the car, sort the car out and change the cam when the weather turns cold again??
