92/92, plug & play ?
Old May 3, 2009 | 03:04 PM
NitrOmm's Avatar
Default 92/92, plug & play ?
getting the ported 92/92 fast. Can I expect to bolt it up and at least run somewhat efficiently.
The reason for asking is: I recently rebuilt the motor (and Mods below), while tuning on the dyno the clutch was breaking loose at 5200 RPM. Now, I am prepping for an LS7 clutch install as well as a much needed tranny rebuild. I will have to drive the car for 500 miles for break in. I was hoping to add the ported 92/92 at the same time. Then get a retune in a few weeks.
What have you guys found when installing the intake & TB? Will it be drivable ?
Old May 3, 2009 | 03:09 PM
02BLKWS6MD's Avatar
I dont see why it wouldnt be drivable, since your gonna be taking it easy for 500 miles and your getting it retuned anyways. It might idle a little high because of the throttle body, it may have a larger idle hole in the throttle blade.
Old May 4, 2009 | 07:50 AM
teke184's Avatar
may have some touchy idle issues.
but mine started right up.
although it was way lean....so i wouldn't go WOT.
Old May 4, 2009 | 08:30 AM
black00ssFL's Avatar
There's no reason not to take it to the dyno during break in. The breaking in has to do with shifting and slipping from a stop. Once it's in gear and the pressure plate is against the flywheel, there's no movement from the clutch. Take it to the dyno, you'll be fine.
Old May 4, 2009 | 09:48 AM
Steve Gunn's Avatar
I'm not sure I would worry too much about going the full 500 miles with a stock style clutch. Plenty of people hammer new Zo6's right out of the box with no issues down the road, but at the same time, I guess it couldn't hurt? A couple of hundred miles should be ok, IMO.
Old May 4, 2009 | 11:12 AM
98TA6.0's Avatar
that's funny i just found this thread. a guy here in Hawaii installed a Vengeance ported FAST 92/92 with FAST 42 lb injectors on his stock longblock MS4 Z28. he drove it about 5 miles to the tune shop and during that time (he seriously kept it below 4K the whole time, i swear) he developed a "slight" rattle and a bit a blue-ish smoke. later on the dyno it developed into a heavy oil fog and a heavier knock. turns out the cylinders were washed and spun #3 main bearing. wheni drop my new motor in i'm gonna drive it to the tuner with the LS1 intake/injectors and install it in the parking lot. i would say try it and if it doesnt work out then you get to build a badass shortblock. good luck
Old May 5, 2009 | 05:20 PM
NitrOmm's Avatar
Good points, do you think that applies to the tranny as well.
