Spark Plug wires
Old Nov 1, 2003 | 05:01 AM
LS1FIRE's Avatar
Question Spark Plug wires
Hello.Is is it neccesary to install the factory spark plug heat shields when installing aftermarket plugs?
Old Nov 1, 2003 | 05:27 AM
jrp's Avatar
jrp
SN95 Director
i do, dont know if its neccessary though.
Old Nov 1, 2003 | 06:29 AM
LS1FIRE's Avatar
What kind of wires do u have?
And what is the better spark plug wires.Taylor 10.4mm or the MSD?
Old Nov 1, 2003 | 07:58 AM
cyphur's Avatar
I would, as GM probably put them there for a reason. I have no reason to think any aftermarket wires have any more of an ability to resist heat's effects. Engine blocks get kinda warm as well all know.
Taylor are supposed to be some top of the line wires. I ran MSD 8.5's with absolutely no problems. Good wires, less expensive then Taylors. The stock wires are great to be honest, as long as they are in good condition. Really no reason to replace them. I replaced mine only because a few went bad(no idea how the previous owner treated the car).
Old Nov 1, 2003 | 08:13 AM
destroyerSS's Avatar
i have taylor 10.4's with no heat shields,no problems. Very happy with these wires since i put them on 2yr's ago
Old Nov 1, 2003 | 09:45 AM
Mean Machine's Avatar
i've got the taylor 10.4's as well. i don't think it's possible to install the heat shields over the boots on those, at least i couldn't. i haven't melted one yet.
Old Nov 1, 2003 | 10:29 AM
LS1FIRE's Avatar
Anyone with MSD Wires had a problem installing the Heat shields?
Old Nov 1, 2003 | 10:59 AM
onyxxtreme's Avatar
i ran with MSDs and no heat shield for about 6 months and 7k miles, no problems. The #7 plug boot was actually resting on the header, still never melted.
Then i ran about 1k miles with the heat shields on, just for safe measure.
Dont really matter in my opinion, either way shouldnt be a problem.
Old Nov 1, 2003 | 06:03 PM
jrp's Avatar
jrp
SN95 Director
i run the taylor 8mm and they've been shitty to me keep breaking, even when pulling from the boot. dont know what im gonna replace it with yet.
Old Nov 1, 2003 | 07:42 PM
HOTROD98Z's Avatar
I run the taylors on mine, with no heatshields and they have held up fine for about a year and half now.
Old Nov 1, 2003 | 08:56 PM
blk~2000~Z28's Avatar
I run Taylor 10.4 and use the heat shields on them. It is a pain in the *** to get them over the boot but I think it is worth it, b/c you can never be too careful. Do they need the heat shield? "Probably" not.
Old Nov 1, 2003 | 09:51 PM
SMOKIN01TA's Avatar
the taylor thundervolts are great wires. i have had the same ones for 2 years, they are on their second car and still work great. no heat shield is required.
Old Nov 1, 2003 | 09:54 PM
ss rally red's Avatar
I run the MSD wires, no sheilds no problems.
Old Nov 1, 2003 | 10:21 PM
LS1FIRE's Avatar
I wanna try and get the best plugs that the heat shield can go on.Is it easier puttion on the heatshield on THE msd or Talyors
Old Nov 2, 2003 | 12:05 AM
I do not know about the MSD's but the Taylor's are not that difficult that a DIY mechanic could not put them in the stock heat shields.
Old Nov 2, 2003 | 12:23 AM
LS1FIRE's Avatar
What is a DIY mechanic?
Old Nov 2, 2003 | 11:09 AM
onyxxtreme's Avatar
DIY= Do it Yourself
the heat shields fit on the MSD's just fine too
Old Nov 2, 2003 | 07:04 PM
VT_01_SS_ls6's Avatar
i have the Holley's... no problems with heat at all
Old Sep 23, 2010 | 03:21 PM
oboro's Avatar
whats up guys, I used to run msd 8.5 super conducter's. I just bought taylor thunder volt 50s and a new set of TR6's. istaling the taylors i feel like the wiers are not cliking on the plugs. Do you have to push realy hard for them to slip on? i dont want to mess them. And can they be taken of the plugs / coils and put back on ?
Old Sep 23, 2010 | 03:40 PM
JustAnotherLS2's Avatar
70k miles still on stock wires, no heat shields, no problems yet, with Kooks 1 7/8. When I do get around to changing the wires I probably will put the heat shields on though. You can naver be too safe. Last time I checked IIRC the the heat shields are around $50. IMO, to me, they are worth it. Are they need, probably not.
