removing stock muffler in one piece??
Remove the Passenger side of the panhard, and completely remove the brace (removing just the passenger side won't do any good since it is direct-bolted w/ 3 bolts to the underbody).
Remove the Passenger side shock and spring. And if you have the RR wheel off, this should get you close.
Like I said, I'm changing bushings anyway.....so I went ahead and pulled off the sway bar and the passenger LCA as well.
Just remember to snug a jack to the bottom of the diff to keep the rear from twisting.
BTW, I know it can be re-welded, and I even have my own welder, and could do it myself easily. I just chose that route for personal reasons.
