BBK Throttle Body Question?
Old May 15, 2009 | 02:06 PM
BadgeZ28's Avatar
Default BBK Throttle Body Question?
I picked up a used BBK 80 mm throttle body. There is a thin layer of black stuff around the throat of the TB right were the blade sits at idle. My initial thought was a factory applied coating that helps the blade seal. Now I am wonder if this is normal or a build up from use?
Old May 15, 2009 | 02:21 PM
hitmanws6's Avatar
its build up. go buy a can of carb cleaner and clean it up
Old May 16, 2009 | 03:56 AM
transwiz's Avatar
I use carb cleaner or MEK.It will clean right up.
______________________
2000 t/a ws6 with lots of mods
Old May 16, 2009 | 09:43 AM
BadgeZ28's Avatar
Thanks guys. Got it cleaned
