os sensore wireing
Old May 18, 2009 | 08:36 PM
Juicemonkey's Avatar
Default os sensore wireing
got an lq9 harness have the signal wire pinouts on the ecu connectors, but there are 4 wires for the 02 sensors, I know black is ground one is signal, any one know what the other 2 wires are or have a diagram for it, my plugs on the harness are missing so I have to wire them.. thanks guys
Old May 18, 2009 | 10:20 PM
kdick91's Avatar
The other two (usually the same color, but not always) are the O2 sensor heater. Not needed, but will throw an SES if not hooked up.
Old May 18, 2009 | 11:13 PM
so the 2 white wires are the heated wires? these just get 12v correct?
Old May 20, 2009 | 10:02 AM
ok someone has to have used a bosch 02 sensor, all I need to know is what color harness wires go to what color 02 sensor wires on a 99+ ls1 engine. Someone has to have done this. what, you guys dont use 02 sensors?????
