cut out vs. duals
I went with the Y-Pipe setup paired with a cut out since cops around here are overzealous about hounding cars with loud exhaust....
I have a Hooker Aerochamber that is only slightly louder than stock at idle and somewhat louder when going WOT
I like my setup for what it is...True Duals sound awesome but I'm over being obnoxiously loud all the time. It's nice to flip a switch and go back to sounding stock, or closing the cut out half way for a in between sound
although bullets tuck up a little better in the trans tunnel....the sound improvement by going with a full size case like the magnaflow 4x9s is AWESOME.
as quiet as a regular catback when cruising
but mean at idle
and down right nasty when you open up the loud pedal.
http://www.youtube.com/watch?v=CATYjAZ7pqg
http://www.youtube.com/watch?v=W59xRdjOotk
My brother ran 3" duals on a lowered TA and didnt have much trouble...as long as you remember they are under there before you crest a driveway or something with any speed...
One other result I experienced, while not necessarily typical, was a significant increase at the track. I went 11.93 at 113 MPH with the duals, and 11.62 at 116 with the ORY/catback/cutout setup. Similar weather conditions and only change on the car was a removed swaybar and a little less fuel in the tank. Like I said, not necessarily typical, but something to think about.
Even though you're lowered, you can run 3'' true duals. Both of my cars have 3'' true duals. And both exhausts go over the axle. However, any dual setup that goes over the axle will require a panhard relocation bar.
