Removing valance/ cooling problems?
Old May 26, 2009 | 01:33 PM
bracketracerZ28's Avatar
Default Removing valance/ cooling problems?
If I remove my valance under the front, will this affect my car cooling at all?
Old May 26, 2009 | 01:40 PM
witry's Avatar
YES def. it will thats how these cars get their airflow from the bottom only or the fans if you have them on all the time and thats not always sufficient keep it its there for a reason
Old May 26, 2009 | 01:46 PM
I thought so. my car is so low that it is tripping the beams falsely at the drag strip with that valance. is there a better system or set up? I was thinking of removing the bumper bracing and the foam to get more air to the radiator. currently I use the slp lid. Any thoughts?
Old May 26, 2009 | 02:02 PM
SSdreamz's Avatar
put it back on
Old May 26, 2009 | 02:20 PM
TooLateVTEC's Avatar
Bring a friend to the track and get him to help get you lined up in the beams with the wheels and not the valance. After a few times, you should get used to where you need to be.
Old May 26, 2009 | 02:26 PM
Kingc8r's Avatar
As others have said, yes it will affect the cooling of your car
Old May 26, 2009 | 04:44 PM
appreciate the input. I was hoping there was another way but I will probably have to adjust the ride height back up
Old May 26, 2009 | 09:21 PM
VIPRETR2's Avatar
I've taken it off at the strip with no adverse affect on cooling (didn't help e.t. either though). I wouldn't suggest driving around like that though.
Larry
Old May 28, 2009 | 02:56 PM
Larry
Yeah, kind of what I had in mind. I hardly drive it except to the track.
Old May 28, 2009 | 05:33 PM
69lemansguy's Avatar
if its that low, maybe you could just trim it?
