Possible blown headgasket?
I ran it with the cutout open and didn't notice smoke, but when I capped the cutout and ran it through the stock catback, I noticed white smoke coming out of the tailpipes. I checked the oil, and it doesn't have any noticiable oil leak, nor has there been any leaking fluids under the car where I have it parked.
One thing to note is that the previous owner only ran the car with the cutout open, as the car doesn't have an e-cutout, and me capping the cutout was the first time it has been done. Not sure if that would make a difference.
Does it seem like I am dealing with a headgasket and are there any types of tests I can do to find out? The car was still pulling like a raped ape and its not throwing any codes. Thanks in advance.
Hope this helps!
Car has 125k on it, i'm hoping its just running rich. I know I can smell gas pretty often at a stand still, so i know it has to be running a little rich atleast.
Hope this helps!
I'm still concerned, as there was a good amount of smoke coming out of the tail pipes the other day after I got on it. I haven't got on it since then, and I havn't noticed any smoke coming out of the tail pipes after normal driving.
Is it normal if the car was running rich for the smoke to occur? And if I did have a blown headgasket, would there be smoke always coming out of the tail pipes, or just after I got on it?
Maybe youre just beginning to burn a bit. If youre temp, oil level, coolant level are all normal and no sign of water in engine oil, I say run it til it becomes worst!
Maybe with all the mileage you have some sort of crap residue in the exhaust!!??
