Code PO 171 & 174
Old Jun 4, 2009 | 11:38 AM
earls02ws6's Avatar
Default Code PO 171 & 174
I am having a problem with lean condition codes PO171 and 174 on bank 1 and 2 on my 02 WS6
I replaced the sparkplugs, not because of this problem but cause it was time, I have replaced the Mass Air Flow Sensor
The car is stock except for SLP lid, empty cats and Corsa cat back the car has 107K miles on it.
The car intermitantly runs bad and the SES light comes on and then something will change and it will run great and the light goes out and then back to bad and the light back on.
I have reset the computer after changing the MAF sensor and still the same problem
I have not touched the o2 sensors because I am getting the lean reading means that they are reading and reporting so there for working or is this not the case, I know a vacuum leak will cause this also but there are not a lot of vacuum lines to check.
I have owned this car since it had 6000 miles on it and this is the first problem I have had that I can figure out.
Any help would be appreciated
Old Jun 4, 2009 | 03:46 PM
earls02ws6's Avatar
Hello, No Help ?
Old Jun 4, 2009 | 03:52 PM
TooLateVTEC's Avatar
Try putting a new fuel filter on it.
Also check/clean the air filter.
Old Jun 4, 2009 | 03:58 PM
earls02ws6's Avatar
new air filter and fuel filter
are the fuel pumps likley to get week and cause this or would the pump just compltley fail
Old Jun 4, 2009 | 04:33 PM
69LT1Bird's Avatar
How about putting a fuel pressure gauge on it? Might be a good place to start.
Old Jun 4, 2009 | 05:12 PM
5w20's Avatar
cracked lid or one not sealing correctly...exhaust leaks?
Old Jun 4, 2009 | 10:29 PM
massls1guy's Avatar
I just had P0174. It ended up being a hole in a PCV hose. I changed most of the PCV hoses when I swapped in my LS6 valley cover a while back. I left the original ~3" hose that connects between the PCV valve and the intake manifold and that's where the leak was.
Old Jun 5, 2009 | 12:28 PM
corvet786c's Avatar
I had the same code P0171. There was a leak from rubber intake hose on passengerside goin into intake I just put a zip tie there and fixed the problem. It is unmetered air gettin in. If u seal it off that should help you!!
Old Oct 2, 2009 | 06:25 PM
docdiggy's Avatar
I was wondering if you got your problem fixed?? I have the EXACT same problem. I am going to replace the intake port gaskets and see if it works. I know there are no vac leaks. I have had this problem for a year now. It's getting worse latley. The fuel pressure is also on the list of things to check.
Old Oct 15, 2009 | 04:00 AM
ZEPHYR-ILL's Avatar
Default SAME problem.
I have the same P0171 & P0174 codes right now. I have had a cutout installed for about a year. Would that throw any codes? I wouldn't think so since I haven't had any problems since recently. I also ONLY use Shell or Chevron gas, (premium). Any thoughts would be greatly appreciated!
Old Oct 15, 2009 | 02:48 PM
01'SSLSX's Avatar
check u'r o'2 sensor, a bad Cat gave me that code before
Old Oct 15, 2009 | 04:21 PM
frawsty's Avatar
i have the same problem and have replaced the rear o2s and checked fuel pressure and have found no vacume leaks any help would be awesome could it be that my rear o2 sims are bad
Old Feb 13, 2011 | 02:54 AM
ZEPHYR-ILL's Avatar
Default Duh!!!
So, I found a pea-sized hole in one of my vacuum hoses. That will throw those codes. Just in case anybody gets these codes, check your hoses!
Old Feb 13, 2011 | 04:57 AM
UnZFeat'd's Avatar
I had these two codes showing up a lot and it turned out to be a leak in my EGR pipe going into my TB. I actually disconnected my EGR in order to pass smog. Pretty wierd, but try it out.
Old Feb 13, 2011 | 09:16 PM
BRUTL's Avatar
#1 cause for a 171 or 174 code is the motor pulling additional air after the MAF. Grab a can of throttle body cleaner, and start spraying your rubber hoses and intake mating surfaces while the vehicle is running and listen for the idle to increase. When it does, you've found the area of your issue.
