BBK intake and 80mm TB
Old Jun 4, 2009 | 11:07 PM
Justin Gibbons's Avatar
Default BBK intake and 80mm TB
Recently installed my BBK 80mm and intake and the thing sounds like a vacuum cleaner especially on cold startup, as idle settles so it does, still you can hear it sucking air. what is happening?
Old Jun 5, 2009 | 12:48 PM
Anyone?
Old Jun 5, 2009 | 01:04 PM
jrpimp00's Avatar
Is there a question in there? Anyway do you have any pics of your BBK installed? PM me the price you paid if you got it new
Old Jun 6, 2009 | 01:11 PM
Soul TKR's Avatar
sounds like a vacuum leak... if the plate on the bottom of the intake isn't lined up correctly with the gasket when screwing it in, it can easily cause a vacuum leak... btw, make sure and put blue loctite on those bolts underneath. After a while, vibrations will cause them to back out. Last time my intake was pulled we found 5 bolts just laying in my valley cover...
Old Jun 6, 2009 | 01:15 PM
726.0chevelle's Avatar
13 Second Truck Club
some intakes make that noise horsepower tv bolted on a fast 92 92 on a lq4 and it made the same noise as you described if it runs good screw it
Old Jun 6, 2009 | 03:13 PM
Soul TKR's Avatar
I wouldn't be so quick to say that "some intakes just make noise, screw it"...
he could possibly have a problem here... if it is a vacuum leak, it would make him run lean. That's not something you wanna do...
not saying you have a problem, because of course I haven't heard it in person... but something to look into and be on the safe side...
I will say that my BBK made a noise much like you describe... once I pulled it back off and locktited everything and made sure all the gaskets were properly lined up, the noise went away and hasn't come back since... and might I add the car runs much MUCH stronger now...
Old Jun 7, 2009 | 10:52 PM
I made a mistake in the earlier post in saying that it is sucking air until it settles down, but it actually just barley idles when cold, slight backfires/popping, idles at like 500rpms, sucking air like crazy. It slowly raises as the car warms up after about 2-3min...but there are several issues going on with my car right now..
https://ls1tech.com/forums/pcm-diagn...32-others.html
Old Jun 14, 2009 | 11:41 AM
evangto87's Avatar
did the codes you are throwing start after the intake install??
