Is the IAC my problem? Inconsistent idle @ startup
Old Jun 5, 2009 | 06:56 AM
bigburb's Avatar
Default Is the IAC my problem? Inconsistent idle @ startup
When ever I first start up my car its seeks a little bit to find the right idle. For example it starts right up but then comes back down to 400 RPM, then bounces around 800-1000 RPM a couple of times before it settles down. Also when I try to start it with the AC is on it has a real hard time staying running and sometimes dies. If its been running for more than 60 seconds there's no problem, its just on start up. My tuner said this was the IAC valve getting slow, does that sound right? Just wanna know for sure before I drop $100 on a new one. Thanks.
BTW I have a GM ASA Cam, full exhaust, ported and expoxied TB, and custom dyno tune, if that helps any.
Old Jun 5, 2009 | 08:19 AM
bigburb's Avatar
Did some searching, could it be the epoxy mod? I'd rather have a consistent idle and be able to start it with the AC on then have 5 extra HP at 6000 RPM. should I remove it?
Old Jun 5, 2009 | 08:20 AM
69LT1Bird's Avatar
Have your "tuner" monitor the IAC data to see what it is doing. Maybe he didn't tune the closed loop/cold start areas?
Old Jun 5, 2009 | 08:27 AM
bigburb's Avatar
I've had it tuned by two different guys, it got better with the second tune but still not just right. On the first tune I couldn't even start it with the AC, and I had to let it find its idle before taking off. On the second tune I can take off when I start it and it'll start with the AC on but it doesn't like it much.
The second guy who tuned it seemed like he knew his stuff (he tuned for 3 performance shops including his own)
Old Jun 5, 2009 | 09:02 AM
bigburb's Avatar
just went out there and looked at it, I have two fairly large holes drilled in the epoxy, probably 3/8", AND a hole in the TB blade.
Old Jun 5, 2009 | 09:14 AM
69LT1Bird's Avatar
Who did all the hacking?
Old Jun 5, 2009 | 09:32 AM
bigburb's Avatar
previous owner. Actually I just looked at a stock TB and it looks like they all have the hole in the TB blade.
Old Sep 15, 2009 | 11:58 PM
connexion2005's Avatar
Just to clarify, I'm the previous owner but the the throttle body is a Jantzer product. All TB blades have an idle hole. Some people enlarge them to help with this issue. The 2 holes in the epoxy are absolutely necessary as they feed the fresh air line for the pcv system and the return for it just after the pcv valve. All stock units have them but the epoxy smooths the air flow entry into the motor rather than creating turbulence at the roughly cast factory ports. The issue IS in the tune...
Old Sep 2, 2010 | 06:29 PM
emenny81's Avatar
I have the same problem, were you able to fix it ???
http://www.ls1.com/forums/showthread...09#post2434009
This guy changed the TPS....
