Can I ditch the EGR?
Old Jun 7, 2009 | 08:19 PM
Biffstupid's Avatar
Default Can I ditch the EGR?
I'm in the process of putting lt's on and was wondering if i can get rid of it. I have seen ls1's with out it. Any help would be great
Old Jun 7, 2009 | 08:26 PM
Johns00Z28's Avatar
Yes you can!!
Old Jun 7, 2009 | 08:48 PM
Biffstupid's Avatar
I just read some of that sticky above. Will it run ok without a tune right away or like ****? I'm running an oryp so no cats... and I can deal with the ses light as its been on forever from my two crapped out stock cats.
Old Jun 8, 2009 | 08:21 AM
Johns00Z28's Avatar
It shouldn't run like **** but you won't see the full benefit of the headers either until you get it tuned.
Old Jun 8, 2009 | 09:37 AM
TooLateVTEC's Avatar
It wont need a tune from losing the EGR, it will just have an SES light b/c the valve isnt working and will make the ECM lose it.
Old Jun 8, 2009 | 11:02 AM
mook99ta's Avatar
all you get is an SES and a cleaner engine bay from dumping the EGR. Go for it!
Old Jun 8, 2009 | 11:42 AM
16floz470ml's Avatar
There is a table for the egr that alters fueling according to temperature. You need to zero it out.
Old Jun 8, 2009 | 12:09 PM
CuNfUzEd's Avatar
Not only can you my friend!!!! You should! LOL Save the smog pump and use as a vac pump. The crap is not entirely worthless.LOL
Old Jun 10, 2009 | 02:15 AM
Biffstupid's Avatar
Dumped the EGR and the AIR and got the plugs and wires on, fired it up with open headers for a minute... sounded so nice. The one thing I had to do was put some heat shield over a few of the spark plug wires because they were a little close to the headers. is burning spark plug wires a common concer with lt's?
Old Jun 10, 2009 | 03:00 AM
iowackers's Avatar
Bye Bye EGR!!!
Old Jun 10, 2009 | 03:05 AM
SMOKNSS's Avatar
Not usually. I've never had a problem until I got a wild hair in my *** and decided to try the Summit brand wires. No matter what they just lay over on the primary. I got some heat shielding Im gonna put on them until I get a new set of wires. But EGR and/or Air pumps are the FIRST things to go on the cars we mess with. LOL
Old Jun 10, 2009 | 03:57 AM
Joshiedoom's Avatar
and/or
Old Jun 10, 2009 | 06:19 AM
Codprice's Avatar
just get the codes out before you need inspection. My guy couldnt pass me since the SES light was on. All computerized system now. I miss my 94 sometimes...sometimes
Old Jun 16, 2009 | 05:44 PM
Glenn98ZM6's Avatar
anyone got the part number for this?
http://j.b5z.net/i/u/2098530/i/DSCN3705_ezr2.JPG
Old Jun 16, 2009 | 07:31 PM
Deviant LS1's Avatar
GM EGR block off plug
#12558346
Old Jun 16, 2009 | 07:35 PM
Biffstupid's Avatar
I just pinched it down flat
