Starter motor
Old Jun 12, 2009 | 04:11 PM
nike5's Avatar
Default Starter motor
Starter motor mounting problem.
I have a crate engine/gearbox (LS2 with T56 Tuet2066)
The starter motor fits the engine and alligns to flywheel (without gearbox)
The gearbox attaches to the engine (without starter motor).
http://s685.photobucket.com/albums/vv216/nike5-ls2/
Obviously I have the wrong starter motor.
Not sure how to describe it, the sheild that covers the teeth hits the bell housing. I just can not get the starter in the hole.
What starters are available.
If I look to after market suppliers what information do I need to give them.
Any help would be appreciated
Old Jun 12, 2009 | 09:07 PM
S10xGN's Avatar
I was about to say that looks exactly like my '03 Corvette starter until seeing the next-to-last pic. My "inside" bolt is much shorter, maybe 1 1/2" long while the outer bolt is maybe 4" long. That longer cast-in bolt boss may be interfering with the bellhousing...
Russ
Old Jun 14, 2009 | 08:16 PM
PKC-Z71's Avatar
Your starter in the picture is a Lester #6492 (GM P/N #9000853 or 12563907). Obviously it takes the two equal length mounting bolts. The other two factory starters that I know of for the LSx motors are the Lester #6482 (GM P/N #9000834 or 9000866) which uses the short inboard mounting bolt, but completely interchanges with the 6492.
The other one comes on the 04-06 GTOs- it's a Mitsubishi starter (Mits. P/N #M0T85582
or GM P/N #92169668) and has the equal length mounting bolts as well:
Hope that info helps.
Old Jun 15, 2009 | 12:40 PM
zman1969's Avatar
LS1 and LS2 use different starters due to the bellhousing - dont know why maybe since the GTO was holden built check out this info here : http://www.pro-touring.com/forum/sho...s1+ls2+starter
Old Jun 16, 2009 | 02:49 PM
nike5's Avatar
That explains a great deal, thank you very much.
Looks like I have a LS2 bell housing and a LS1 starter.
All the best Kevin.
Old Jun 25, 2009 | 06:26 AM
FinnLS3's Avatar
Hi ,
Does anyone knows , is that same starter in LS3 ?
-matti
