OIL temp sender?
Old Jun 16, 2009 | 03:31 PM
zeake's Avatar
Default OIL temp sender?
I want to add an oil temp gauge to my truck. I am running 8lbs of boost via a trickperformance turbo kit in a 6.0. I am really wondering how hot my oil is
How does a vette determine its oil temperature? Is it in the oil pressure sender? I have searched and searched. I know someone here knows.
Thanks in advance.
Jake
Old Jun 16, 2009 | 03:35 PM
Bad Blue WS6's Avatar
above the filter is a T fitting. On a vette, its already ready to go, on a F-body, you will have to tap the side the sender goes in to.
https://ls1tech.com/forums/generatio...emp-gauge.html
http://xse.com/leres/ss/gaugepod.html (this one is a big help)
https://ls1tech.com/forums/generatio...e-install.html
Old Jun 16, 2009 | 03:38 PM
zeake's Avatar
So the vettes have a sender. Is it specifically an oil temp sender or pressure and temp? Anyone have a part number? I am actually putting this on a truck. Thanks for the help.
Old Jun 16, 2009 | 03:43 PM
that part im not sure of (its been a bit since i did gauges) but it is detailed in that link i wrote is a big help next to. I want to say they do, as if you were to buy that T fitting, it would already be drilled out (wrong size though) vs buying a F-body type you would have to drill and tap it out. For the vette one, you would need to get the adaptor fitting to make it work
Old Jun 16, 2009 | 04:02 PM
zeake's Avatar
WOW Thanks so much for the info. I have been looking for this for a while now. I think I will end up putting a cooler on it after I see how hot the oil gets.
Old Jun 16, 2009 | 04:24 PM
jmm98LS1's Avatar
I've got a brand new autometer ultralite 1 1/6" oil temp gauge w/sender, $40 + the ride if you're interested.
Old Jun 16, 2009 | 04:38 PM
zeake's Avatar
Got any pics?
Old Jun 16, 2009 | 04:41 PM
zeake's Avatar
2 1/16 or 1 1/16 ? If you want email me some pics zeake13@yahoo.com
Thanks
Jake
