Fernco installed
Old Nov 11, 2003 | 04:20 PM
chrismcdaniel's Avatar
Default Fernco installed
finaly figured out how to install the fernco, it was realy easy so i guess i should say i finaly got up off my but and did it, the Key to the install with out cutting it was to heat it up in the microwave for 1 minute and then with gloves on (learned the hard way) you can form it to fit and stretch it around the throttle body. looks awsome
Old Nov 11, 2003 | 05:40 PM
ALPINE's Avatar
Without the clamps.
Old Nov 11, 2003 | 07:38 PM
98SS Blackattack's Avatar
Mine will go on the TB. ItsThe angle that wont work. It may be the lid is alittle different than others, but trust me it wont bent like that on my car.
Old Nov 11, 2003 | 08:21 PM
i had trouble with the angle too, but like i said i was able to heat the rubber up and it just molded perfectly even with the weird angle, no problems
Old Dec 27, 2003 | 04:12 PM
Cokeroker's Avatar
Default Fernco Fitting Bellows
THIS WAS the most helpful with the FERNCO fitting.... a little heat in the microwave on HIGH 45-60 seconds was just enough to make it plyable enough to make it over the TB and cut the angle for the MAF... thanks a bunch for the info....
