What headers are these?
Old Jun 23, 2009 | 02:31 PM
XxWICKEDSSxX's Avatar
Default What headers are these?
Think they are pacesetters but not quite sure... has all emission bungs on the front tubes and one other thing that can be blocked off on the passenger header. Also can someone verify that these can be used on an 01 SS
I noticed on my factory manifolds that the driver side emission thing is on the second tube not the first, is that a problem? Will I need oxygen sensor extenders for where they plug into the collector? Does my car have 2 or 4 oxygen sensors?
Old Jun 23, 2009 | 02:41 PM
Badguy7's Avatar
Yes, you will need O2 extensions, and our cars have a total of 4 Oxygen Sensors. 2 fronts (the ones you put in the headers), 2 rears (these go after the cats). Emissions fittings shouldnt be a problem. Im not sure what headers they are, are they stainless? If stainless, there not Pacesetters and i dont think pacesetters have the o2 bungs on the outside like that one header in the pic does. Maybe Ebay headers??
Old Jun 23, 2009 | 02:48 PM
I just figured out they are Jet Hot headers, now my only question is what differences there would be between the 98-02 year models with the emission systems. Im trying to figure out if these are the right ones for the 01 year model
Old Jun 23, 2009 | 02:51 PM
bad72c10's Avatar
I agree that they aren't pacesetters. The headers that have the o2 bung on the opposite side that i know of are hookers and jet hots.
Also, those headers have a flange for EGR, which your 01 car will not have. So you are going to have to block it off. This may cause that fitting to eventually crack at the weld and possibly blow off leaving you with a hole in your primary. But they will work fine.
Old Jun 23, 2009 | 03:02 PM
FormulaZR's Avatar
Couldn't he just have that fitting cut off and patched now?
Old Jun 23, 2009 | 03:06 PM
Yes I could do that pretty easily. Ok so im thinking the only difference between the two part numbers for 98-99 and 01-02 camaros is that on the driver side of an 01 the emission thing is on the second tube, and on 98's its on the front. Can someone with a 98-99 camaro verify this for me??
Old Jun 23, 2009 | 04:06 PM
bad72c10's Avatar
The main difference is the EGR tube that is unnecessary. I don't believe it is the air fitting.
Old Jun 23, 2009 | 04:49 PM
01ssreda4's Avatar
block off the one fitting for EGR on the pass header and everything else will bolt right up. The AIR tubes are somewhat flexible so they will bolt to whichever tubes the fitting is welded to.
Old Jun 23, 2009 | 04:53 PM
TooLateVTEC's Avatar
Those are Ebay specials.
Notice how the driver side header the collector is angled upwards slightly? Dead give away, lol.
Old Jun 23, 2009 | 10:39 PM
mvvette97's Avatar
yep I agree
Old Jun 24, 2009 | 01:37 PM
Id rather it be angled up then down... I dont feel that they are junk, the welds are very well done and seems to be a good quality metal. Either way they will flow better than a stock manifold so im happy for $250.
Jet hot is not the brand, just the company that coated them. They said they are either hedmans or hookers, those are the only two brand headers they coat for f-bodys
Old Jun 24, 2009 | 02:18 PM
mvvette97's Avatar
those look like stainless, not coated but I may be wrong
Old Jun 24, 2009 | 02:26 PM
spy2520's Avatar
why are the bolt holes so damn big?
Old Jun 24, 2009 | 02:29 PM
subhumanzz's Avatar
sure dont look coated to me. i am 99% sure they are the ebay stainless headers.
Old Jun 24, 2009 | 02:30 PM
subhumanzz's Avatar
wow just noticed that too.
Old Jun 24, 2009 | 05:20 PM
I didnt say they were junk. They are stainless steel though, which is good.
They dont look bad at all, aside from the monsterous bolt holes.
I wouldnt want my collector angled either way, down the y-pipe hits the ground and up it hits the floor.
Not a bad price, but now you have to find a y-pipe that will mate up to them. redfbird99 on here found a generic stainless y-pipe on ebay that bolted up. Hit him up if your want to find out exactly where he bought it...it was off road too if that matters.
Old Jun 25, 2009 | 05:19 PM
Fb0dy0nly's Avatar
those aren't coated, the metal is polished stainless steel. throw um on and start it up!
