Where to buy fuel injector o-rings - HELP!
I have a 98 vette and I need to replace the fuel injector o-rings. The GM dealer does not carry these...you have to buy the whole injector!! Does anybody know where I can get these? If they don't sell a kit what size o-rings do I need (top and bottom). Thanks!!
By any chance do you know what size I need? I can't imagine that there is a wide variety of these things but there must be a few sizes.
While doing an intake swap I had the same problem, nobody local had the o-rings I needed in stock. After doing a bit of part number cross referencing it turns out a '92 Jeep Cherokee with an I6 uses the same o-rings for its injectors and happened to be in stock at Autozone for $8 for a pack of 12.
It's Gp-Sorensen Part Number: 800-9220, since your doing upper and lowers you will need 2 packs.
Give it a try, worked out for me.
