how much to mill 243s?
Old Jun 23, 2009 | 07:59 PM
fast's Avatar
Default how much to mill 243s?
just looking for a small bump in compression ... so what would the recommendation for milling be? (meaning how much)
shorter pushrods needed with a small mill or just use a checker?
thanks in advance
Old Jun 23, 2009 | 08:27 PM
JScamaro's Avatar
That would depend on what cam you are using, head gasket, and your desired compression ratio.
Old Jun 23, 2009 | 09:03 PM
black01_WS6's Avatar
what he said. we need to know more of the combo, or what you want/have cam wise.
Old Jun 24, 2009 | 10:51 AM
LS1TORQ's Avatar
it is better to use a thinner head gasket like a cometics .040 than to mill your heads. A thinner head gasket improves quench while milling does not and can hurt cylinder head flow.
btw do a search to verify but I beleive a .040 gasket will give you a little over 11:1 compression
Old Jun 24, 2009 | 02:12 PM
fast's Avatar
thanks guys, I'll look into the gaskets instead
