AC compressor making noise when not in use
Old Jun 28, 2009 | 05:35 PM
Tommyv8's Avatar
Default AC compressor making noise when not in use
Last week I put a used AC compressor on my car and had the system charged. Everything seemed ok until yesterday when I noticed a high-pitched metallic grinding noise coming from the compressor when the car is on and the belt is turning but the compressor isn't actually on. When I turn on the AC and the clutch engages the noise stops. Any ideas?
Old Jun 28, 2009 | 10:50 PM
conan's Avatar
The clutch is going bad.
Old Jun 28, 2009 | 11:42 PM
NBM-LS1's Avatar
Most likely it is the clutch bearing. Idk if you can just buy a clutch or not.
Where did you buy the pump from?
