built 4l60e or 12 bolt
Old Jul 4, 2009 | 05:25 PM
97ta383's Avatar
Default built 4l60e or 12 bolt
so i have a little bit of cash coming to me enuff to cover either one which one would you guys do first a built 4l60e with a 3600 stall or a moser 12 bolt with probebly 3.73 gears. My car 02 t/a with full bolt ons 243 heads and a 3000 stall i also have a set of m/t drag radials and lca, sfc, and reloction brackets coming. Also when i get a new torque arm should i get one mounted to the transmission or the trans k member? thanks for the advice
Old Jul 4, 2009 | 05:50 PM
black01_WS6's Avatar
get a chassie mounted torque arm. since you are a A4- I would rebuild the tranny as the rear takes a softer shock with a A4 compared to a M6.
Old Jul 4, 2009 | 07:09 PM
Strahley's Avatar
I'd probably do the rear, as I don't like the idea of dropping money into a 4L60E
Old Jul 4, 2009 | 07:27 PM
Snapps's Avatar
I am with black 01 ws6, I am pretty sure there are guy's running in 10's on there stock 10bolt with a4. Spraying n2o as well. I would say go for the tranny rebuild!
Old Jul 4, 2009 | 07:44 PM
joker machine's Avatar
Get the built trans,the stock trans will break way before the 10 bolt will.
