Fact or fiction: power loss from bad o2?
Thanks for the advice - I know for sure one of the front are bad...so driving without the o2's in place won't hurt the car in anyway? I don't have access to a lift or jack stands (apartment living, gotta love it) are the o2's easily accessible if I were to pull onto a curb or something?[/QUOTE]
You will not want to remove them, you will just have a big hole in the exhaust pipe. I would suggest you just try to get some new ones, I usually get the bosch 13111's because of the longer wire, and they aren't too expensive. You will need a 22mm wrench to remove them if you decide to change them out.
