no turndowns to reduce drone?
Old Jul 8, 2009 | 02:20 AM
WickedSuperSport's Avatar
Default no turndowns to reduce drone?
sorry if this is a dumb question.....
Im going to be putting pacesetter LT's with a stainless true dual system. Instead of having turndowns before the axle, could you reduce drone by just not having turndowns?? and having the pipe just stay straight at the end?? just like when you run it out the back?
Old Jul 8, 2009 | 02:23 AM
also, should i even be thinking about doing true duals if my car is lowered 1.2"??
Old Jul 8, 2009 | 04:45 AM
Joshiedoom's Avatar
Turndowns reduce drone by turning the sound towards the ground. Makes a helleva difference
Old Jul 8, 2009 | 07:53 AM
Flawless02SS's Avatar
Not turning the pipes down will help a little, but I think you will still have a little drone since the sound is still under the car. And yes you can still run duals on a lowered car. If it is done right.
Old Jul 8, 2009 | 10:12 PM
jmm98LS1's Avatar
On my duals I've had them dumped straight down, outward 45 degrees and now with no turn downs at all. Had lots of drone with them straight down, got a little better at 45 degrees out, and it's completely gone now with no turn downs. Just my experience.
Old Jul 8, 2009 | 10:31 PM
TORCHD 02 TA's Avatar
with my cam, and when i had TDs h and 1 chambers.. i though my car was going to vibrate apart
Old Jul 8, 2009 | 11:17 PM
Hamrdown's Avatar
I would have a couple of turndowns fabbed up that can slip on with clamps and set it up turned straight down first, then angled, then off and see which one you like best. If you like it better with them on once you find the right angle then just have them welded up.
Old Jul 8, 2009 | 11:25 PM
merlinn's Avatar
It will help somewhat
