Pacesetter LT's
Old Jul 8, 2009 | 08:49 PM
zamora7's Avatar
Default Pacesetter LT's
Allright guys I just picked up a used set of pacesetter LT's earlier today for my LS1 WS6 and my questioins are:
1. What would be the best fitting y-pipe out ther for these headers would any brand fit them just fine?
2. What kind of gaskets should I use? a new pair of stock gaskets or what?
3. Should I just keep the stock 02's or buy new ones? simulators or just regular ones. I know I need the O2's extensions, too.
4. What aboult the bolts, keep stock ones and put back in the same hole they came out of?
5. Will the headers and the y-pipe line up with my borla catback?
Old Jul 8, 2009 | 10:01 PM
Jason 98 TA's Avatar
LS1Tech Premium Sponsor
Checkout our TSP off-road & cat y pipes, they're both brand new designs & work really really well. Use stock gm gaskets, & if money allows toss a new pair of front o2s up front.
The TSP y pipe will fit to your borla catback!
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old Jul 9, 2009 | 12:25 AM
WickedSuperSport's Avatar
or get a flowmaster Y-merge and have an exhaust shop custom fab up the Y pipe with that. that will definately be the best flowing, sounding, and give the best clearance. A few friends have had the pacesetter Y and TSP Y, then switched to a custom Y-pipe using the flomaster merge and said they would never buy an off the shelf Y pipe ever again.
Old Jul 9, 2009 | 02:43 PM
ds98formula's Avatar
Where do you get the merge from?
Old Jul 9, 2009 | 03:07 PM
LS1nterceptor's Avatar
I'm getting mine from Summit as soon as I get some other issued smoothed out.
Here is the 3" in x 3.5" out
http://www.summitracing.com/parts/FLO-Y300350/
And the 3" in x 4" out.
http://www.summitracing.com/parts/FLO-Y300400/
Old Jul 9, 2009 | 03:36 PM
LS1BLKSS's Avatar
Banned Village Idiot
i would get a custom y pipe... and for the gasket just use your old GM gasket, or get a new one from autozone
Old Jul 9, 2009 | 03:37 PM
LS1BLKSS's Avatar
btw... change the motor mounts now if you plan on doing that later on... it'll save you a lot of time
Old Jul 9, 2009 | 03:56 PM
2001taws6's Avatar
Pacesetter header/ORY will fit fine with the borla. I had the same set up put on my car and the guys that did said they didnt have much trouble getting everything to line up right. As for o2's I left the old ones in but the one only has about 5000 miles on it. I am also catless and not running any o2 sims.
Old Jul 9, 2009 | 04:23 PM
StrokerAce03's Avatar
1. TSP ory; I just finished putting one on yesterday and it fits well.
2. Just re-use the stockers.
3. Get some rear sensors for a Corvette. They have better heaters in them and don't require extensions.
4. Stock bolts are fine; mine are a mix of new and old since I dropped a few and didn't feel like looking for them so I used some of the ones PS supplied
5. Yes.
Old Jul 9, 2009 | 07:30 PM
zamora7's Avatar
should i repaint them on the process? what paint should i use?
Old Jul 9, 2009 | 07:40 PM
Thanks
Old Jul 9, 2009 | 07:48 PM
zamora7's Avatar
Thanks for all of your help guys. I guess I'll go with the flowmaster merge and custom fabbed Y, stock replacement gaskets, but what should I do about paint?
Old Jul 12, 2009 | 09:00 PM
zamora7's Avatar
Already got the flowmaster merge with a custom Y already on it but it was for a LT1 and is a 4in with a reducer to 3in. Got it damn cheap, $20 bucks while picking up a raptor hood for the LT1 T/A. for $200 plus the stocker.
