Is it typical for new headers to smoke?
Old Jul 9, 2009 | 10:29 AM
OneSlowCamaro's Avatar
Default Is it typical for new headers to smoke?
I just installed some long tubes and now when the car is running there is smoke coming out of the engine bay. I think it might just be the paint on the headers, but then it would make more sense if it was coming out of the exhaust. Is this normal or do I have a problem?
Old Jul 9, 2009 | 10:34 AM
therealcreeper's Avatar
did you use PB blaster or anything? that burned off when i first started mine. also maybe if you spilled some oil on the header or it may just be the paint.
Old Jul 9, 2009 | 10:41 AM
i used some liquid wrench to take off the bolts from the old manifolds to the cats, maybe its burning off some of that from the sprays that i missed bolts with?
Old Jul 9, 2009 | 10:46 AM
1redta's Avatar
it is normal for any headers to burn off fluids and residue from the install
Old Jul 9, 2009 | 10:47 AM
Noxious's Avatar
Yeah it's just the grease and oil off your hands. No biggie.
Also if they are painted headers they usually smoke a little when the paint cures.
Old Jul 9, 2009 | 12:01 PM
ChocoTaco369's Avatar
Tech Resident
Yes, when you install headers, lots of white smoke will come out of your engine bay. I just put blockoff plates on my AIR tubes the other day and even they smoked quite a bit for 5 minutes, so expect lots from headers. Especially stainless headers - they smoke a lot.
Old Jul 9, 2009 | 06:13 PM
FIREHAWK#608's Avatar
Default Longtubes
After you install long tube headers they will always smoke from any grease or solvent on your hands and the painted long tubes always smoke a lot because they are burning off all the paint. The ceramic coated headers will smoke sometimes from you handling them but much less.
Old Jul 9, 2009 | 10:21 PM
chevyridinhigh22's Avatar
Perfectly normal...
Old Jul 9, 2009 | 10:51 PM
garygnu65's Avatar
if they are painted headers and the paint starts to fall off ,wipe them down with tranny fluid a couple time to slow down rusting .an old dirt track trick.
Old Jul 9, 2009 | 11:02 PM
LS6427's Avatar
Only way headers WON'T smoke after they're installed is to use medical gloves to install them and get NOTHING on them while you're installing them. Greese, oil, **** like that.
Mine smoke after every spark plug change too. Its just from our grubby *** hands touching them.
Old Jul 10, 2009 | 08:07 AM
SuperSport01's Avatar
All headers smoke some when they're new.
Old Jul 10, 2009 | 08:56 AM
BBYZED's Avatar
I'm installing some LT headers and y-pipe next weekend. I had no idea they would smoke! You guys saved me a LOT of panic and anxiety.
