asp pulley insatll HELP!
Old Nov 15, 2003 | 04:55 PM
jpbgto's Avatar
Default asp pulley insatll HELP!
I am trying to get my crank pulley off with a three arm puller. I just can't get the damn thing to give though. I have already broken the crank bolt and removed all the belts. No matter where i position the arms of the puller it just won't come off. Please HELP so i can quit getting my
Old Nov 15, 2003 | 06:11 PM
Mike K.'s Avatar
most people use the crank bolt as the support for the middle of the puller, Just make sure you have it threaded in enough so that you dont destroy any threading on the crank. The arms on the puller should be on the inside of the pulley (you'll see three tabs) as well or else you could break the pulley. Its on there tight but it will come off.
Old Nov 15, 2003 | 08:12 PM
jrp's Avatar
jrp
SN95 Director
hold it center, make sure the arms are on the tabs and slowly tighten the bolt until it can hold itself up on its own pressure. keep turning until it comes off.
Old Nov 15, 2003 | 08:20 PM
Cal's Avatar
Cal
My puller had a cone shaped piece on the end of the bolt that didn't mate well to the bolt head with it's bumpy raised lettering. I solved the probem by center drilling a cone shape into the bolt head on my lathe. Any machine shop should do this for a minimal charge. Other wise the puller will walk around on the head and never pull straight.
Old Nov 15, 2003 | 08:45 PM
jrp's Avatar
jrp
SN95 Director
hmm, that was a good idea. my puller had the same conical end to but after enough pressure it wore down and flattened out and was able to stay flat on the bolt.
Old Nov 15, 2003 | 08:53 PM
Jorday's Avatar
Another thing that helps is to put some WD-40 on the threads of the puller. Turns a lot easier. I have a flat piece of metal that I put on the end of the crank so I don't have to have any bolt in there to risk damaging the crank threads.
Old Nov 15, 2003 | 09:41 PM
Mike K.'s Avatar
Not sure if this is a good idea but it worked for me to get the pulley the last bit off. a 3/4 socket extension will fit perfectly down the crank bolt hole and will rest against the crank. You can get the extension to the exact length needed to pull the pulley all the way off so you dont even have to wiggle it.
