Should I switch setups?? details inside...
Old Nov 16, 2003 | 12:50 AM
alexWS6's Avatar
Question Should I switch setups?? details inside...
Currently: FLP headers with offroad pipes - 3" cutout - Corsa catback.
Considering: Kooks or QTP 1-7/8" headers - 3" true duals with X pipe - spintech or borla Xr1 mufflers - over the axle through Corsa tips.
The motor is just your basic cam-only 346 for now. Big cubes down the road are not out of the question.
Do I stand to gain much (if any) power?
How different would the sound be?
Any input is appreciated
Alex
Old Nov 16, 2003 | 12:55 AM
Cal's Avatar
Cal
With the 3" duals you will gain power even with a stock motor, and with a cam for sure. They say duals sound best on an LS1, but I 've only heard them on other motors.
Old Nov 16, 2003 | 01:02 AM
alexWS6's Avatar
Thanks. How do you like your QTPs? Are they 1-7/8"?
Old Nov 16, 2003 | 09:10 AM
onebadz's Avatar
I think you should defiantly look into some stepped Kooks if you are planning on going anything other than stock CI. I think for the stock 346 FLPs will be fine. You might consider swapping out your Corsa for 3" True Duals. Good Luck man
WeS
