underdrive pulley or ftra?
1. asp underdrive pulley
2. fasttoys ram air kit
i will probably be getting a 160 thermostat with either but was wondering which mod should i do now and which i should wait and get later. i figure the pulley might be more noticeable but the ram air kit would be more simple to install. i would need new belts and crank bolts for the underdrive and i don't have a pulley puller so the pulley would cost more. whats you guys input what i should do first?
If you're planning on doing a cam swap later, do the FTRA now, and the UD pulley later. This is the case since it's a bit of a PITA to do the swap. Might as well only have to do it once.
