help!!!! injectors wont fit in my typhoon intake....
12 Second Truck Club
hey guys i got a 2001 silverado rcsb im putting a lq9 in, so i got the motor ready to drop in the truck just got to put the intake on its a ls1 96mm typhoon from professional products, so i get to putting everthing together and figure out im gona need to buy a fuel pressure regulator because i have return fuel line which i can fix this, but then i get to putting my truck injectors in(until i can get some 42lbs) and the injector ports on the intake are too big for my injectors so i call up professional products and they tell me that i can buy bigger o rings from a place called kaytechengines.com, and im just now figuring out that ls1 injectors will only work with it so can i still make it work, i couldn't ever find there website so has anyone ever run into this problem....any help is appreciated thanks
chris
chris
