New motor wont start!!
If the preload is correct for that cylinder, and it still doesnt open, then something has happened internally. If a rocker won't move it's either lifter, rod, cam.
Sounds like you will need to pull the engine and/or drop the sump to see whats happening inside
1. Are you using some kind of custom length pushrod? Generally, the Trickflow heads require a longer than stock pushrod.
2. Are the lifters new and if so, did you soak them in oil for a few hours before putting them in?
3. Did you remember to put the rocker rail (the rail that the rockers sit on) back in before installing the rockers?
If you are using stock rocker arms, they should be torqued to 22 lb-ft. This will achieve proper preload assuming you are using the correct length pushrod.
If this is a new engine, you don't really want to go flogging on it until you get some break in miles on it and make sure everything is working correctly.
